Keeping only certain lines in a shapefile
  • Jun 4, 2024 1:43 AM UTC
  • 117 views
cpedron
I am currently working on updating and maintaining a workbench from a previous colleague and am having a little trouble with adapting to a certain aspect of the output schema that we need to follow. The shapefile that we are reading from has multiple very close together lines representing the different vertices of a kerb feature, anywhere from 2-5 lines. Without manually removing the excess lines, is there any way to only keep the lines that would represent the back-of-kerb, or rearmost line.
Forum|alt.badge.img+63
Can you share a bit more information, or a sample, of your source data? That would help people in trying to come up with a solution for you.
cpedron
  • Jun 4, 2024 5:18 AM UTC
This should have the shapefile I have been given to train on attached, and the instruction that caused this issue for me.
