JSONUpdater – How to insert an empty JSON object ({}) instead of string or null?
  • Nov 27, 2025 4:21 PM UTC
  • 99 views
roghayeh
Forum|alt.badge.img+5
Hi everyone,
I’m working with the JSONUpdater transformer in FME and need to add a key called layerDefinition to my JSON. The goal is to have:
"layerDefinition": {}
as an actual empty object, not:
"layerDefinition": "{}" // string
or
"layerDefinition": null
Here’s what I tried:
  • Value Type = Plain Text, Value = {} → Result is "{}" (string).
  • Value Type = JSON/XQuery, Value = {} → Result is null.
  • Value Type = JSON/XQuery, Value = json:object() or map {} → The key doesn’t appear at all in the output.
My JSON path is correct (json["operationalLayers"][0]), and the update type is Insert into Object.
Question:
Is there a way in FME to insert an empty JSON object using JSONUpdater without resorting to a string or null? Or is the only workaround to use AttributeCreator + JSONFragmenter or JSONTemplater?
Any advice or examples would be greatly appreciated!
Forum|alt.badge.img+54
  • Nov 27, 2025 4:50 PM UTC
Have you tried this?
Another option is to put {} in an attribute then use that as the value
