Iterative loops
  • May 16, 2018 10:31 PM UTC
  • 104 views
I want to implement an iterative loop in my workbench. For this I have created a simple "While Loop" construct. The pseudo code is as below
var i, maxval;
i = 1;
maxval = 10
while (i < maxval)
i = i + 1;
print i;
I created a workbench
To implement the looping, the red line should be working but FME doesn't take it.
Please advise for any workarounds or what I may be missing?
  • May 16, 2018 11:05 PM UTC
Hi @josephjose, to perform iteration, you will have to create a custom transformer. See these links to learn more.
However, in some cases, creating copies of the feature could be enough and also effective, without creating a custom transformer.
  • May 17, 2018 12:26 AM UTC
Thanks for the feedback.
I read your link
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/transformers_custom_looping.htm
Don't find any option like described like
Right-click in the workspace and choose Insert Transformer Loop, or select the menu Insert > Transformer Loop.
I am using FME2017. Am I ahead of the game or behind?
  • May 17, 2018 12:40 AM UTC
I read your link
I have posted two links. Why don't you read the first one - About Custom Transformers? There is another link to "Creating Custom Transformers" which you have to learn first if you want to implement a loop with a custom transformer.
  • May 17, 2018 2:24 AM UTC
Hi Takashi. I got it. Thanks
Wasn't checking it in the custom transformers
