Is there anyway to publish parameters in more than a single language?
  • May 26, 2017 6:33 PM UTC
  • 113 views
We are building a data extraction tool based on FME Server. This application build a form dynamically based on the published parameters. It needs to work in french and in english. Since i18n isn't possible on parameters descriptions and alias, we need to rely on a custom format that we put in the descriptions. The application has an additionnal step of parsing the descriptions to get the french or the english names/descriptions depending on the current language of the user.
Is there any plan to support i18n on parameter names and descriptions?
Is there a different way to manage that then the one we use?
Thanks!
Best answer by david_r
As far as I know, there are no concrete plans of supporting multi-language parameters, although I'm sure it's been asked a few times.
Here in Switzerland we have a lot of the same issues with our several official languages that we are required to support. For us, the solution has been to use a custom web (GUI) interface to the FME Server REST API. It is a bit of an up-front development, but fortunately it is possible to make it pretty dynamic, e.g. you can query FME Server for a list of all published parameters on a specific workspace and build the entry form based on that. If you standardize the parameter names, you can also save a lot on translation.
  • May 28, 2017 8:26 PM UTC
Thanks for your answer. We are looking to keep the web interface as simple as possible. We would have prefer FME Server to offer i18n fonctionality at the workspace level.
