Is there a way to write a tables schema and data type out to a text file?
  • Feb 15, 2021 10:02 PM UTC
  • 394 views
darkspatiallord
Forum|alt.badge.img+8
tomf
Forum|alt.badge.img+31
  • Feb 16, 2021 6:05 AM UTC
I'd use the Schema feature from a FeatureReader, exploding the attribute list and then using name (attribute name) and native_data_type to build a text file? This could be done when reading, or add an extra FeatureReader (Schema feature only) after writing out the data.
darkspatiallord
thanks Tom. knew there was a way, just couldnt get brain to function!
Will post result for others to use, as this is for metadata population.
darkspatiallord
Creator > Feature Reader > Attribute Manager > Attribute Trimmer > Text file writer
In Feature Reader set Max features to read to 1.
Change Schema\\Data Feature to be Schema Features
Connect output to <Schema>
Attribute Manager - depends on how you want to expose the values - I used multiple lines and built a new atttribute to populate a text file
$(DATASET)
@Value(fme_feature_type_name)
Attribute_Name Datatype
@Value(attribute{0}.name) @Value(attribute{0}.native_data_type)
@Value(attribute{1}.name) @Value(attribute{1}.native_data_type)
@Value(attribute{2}.name) @Value(attribute{2}.native_data_type)
You can list as many attributes as you need, I didnt make mine dynamic but am sure you could.
Through in the attribute Trimmer to remove any excess lines and spaces from the end.
Write out using text_Line and fan out on the dataset using @Value(fme_feature_type_name).txt
Not to hard after all.
Now just to embed into XML metadata.....
