Is that possible to change size of a feature type box ?
  • Dec 14, 2018 3:03 PM UTC
  • 7 replies
  • 47 views
Cause table & attributes name are longer than the available size. And the over solution is not so simple to use.
  • Dec 14, 2018 3:07 PM UTC
If you hover over the right or left edge your can grab and drag it to any width:
As a GIF:
erik_jan
Forum|alt.badge.img+26
  • Dec 14, 2018 3:20 PM UTC
As a GIF:
This has been available for the last few years. Older versions of FME do not have this capability!
Forum|alt.badge.img+54
  • Dec 14, 2018 3:23 PM UTC
As a GIF:
You can also double click to auto expand to the width required to display the text in full
Yes, if I'm not mistaken it was introduced in FME 2015. Time flies...
  • Dec 14, 2018 3:25 PM UTC
That's a great tip, but I think it only looks at the feature type name, not the attribute names. If only the attribute names are too long, you'll have to expand it manually.
fmelizard
Forum|alt.badge.img+22
  • Jan 6, 2019 5:13 AM UTC
Changes are coming in this area for FME 2019. I think the default behaviour will be to size for fit... Do test the betas, fiddle with the settings, and let us know what you think... (Check the options in Appearance->Canvas Node Display -- should have everything you'd want..)
  • Jan 7, 2019 6:56 AM UTC
Thanks for the tip. Just had a look, works great! :-)
