Is it possible to run a reader after a transformer?
  • Nov 25, 2020 6:43 AM UTC
  • 150 views
I have a SystemCaller transformer that runs a script external to FME, and this script writes out a 2gb csv file.
My aim is to use a CSV Reader and an SQL Writer together to get this in to a database.
The issue I'm facing is that the CSV Reader seems to be a starting point, and I cannot connect the output side of the SystemCaller to the input side of the CSV Reader to indicate that it should run once SystemCaller is complete. Is there a strategy that can be used to overcome this? I'd prefer to keep things in the one workflow if I can.
Best answer by nielsgerrits
The FeatureReader is what you are looking for. I never use the Classic Readers anymore.
nielsgerrits
Forum|alt.badge.img+67
  • Nov 25, 2020 6:48 AM UTC
That's awesome. Thank you!
Forum|alt.badge.img+63
This is exactly the kind of scenario where the FeatureReader (and FeatureWriter) stand out. They give you a lot more options for building complex workflows.
