Is it possible to create a tables in a table in the HTML transformer?
  • May 2, 2022 4:36 AM UTC
  • 314 views
deanhowell
Forum|alt.badge.img+24
I have a bunch of statistics that I want to add to a HTML report similar to the image below. Not all columns have the same number of rows nor is each column / row related across the table. So was thinking that if I could create a table and each cell contain a list or similar.
Any suggestions would be very much appreciated
Thanks Dean
Forum|alt.badge.img+63
I think you can do that, if you have them all as lists you can use a ListConcatenator to put them all in a single attributes. If you set the separator character to <br> and then use a HTMLReportGenerator to create a table with those attributes the browser will interpret the <br> as a newline character and it should render ok.
deanhowell
  • May 3, 2022 7:27 AM UTC
Thanks @Hans van der Maarel​ , yes I think that will work, just need to get the list into the format of {count, aaa, count, bbb}
deanhowell
  • May 3, 2022 7:58 AM UTC
This is the link to my list concatenation question
https://community.safe.com/s/question/0D54Q00009Uuv7RSAR/concatenate-parts-of-lists
deanhowell
  • May 4, 2022 3:02 AM UTC
Just an update and thanks to @Hans van der Maarel​ as the <br> worked like a charm
