Intersector and TestFilter produces result, but no geometry
  • Dec 23, 2024 11:29 AM UTC
  • 9 replies
  • 163 views
scarter
Forum|alt.badge.img+10
Hello Forum,
I have two polygon datasets, each with just one object in it. The edges of the two polygons abut in places.
I’ve created a workspace where I‘m reading in the ‘Above’ polygon dataset and the ‘Below’ polygon dataset. I want to create a line feature of where they share a border.
To do this I’ve used an Intersector which gives me a new _overlaps attribute…
The exact line I require is where _overlaps = 2…
So, I added a TestFilter to filter out where _overlaps = 2…
But when I wrote that to a new feature no geometry was created.
So, I added a LineBuilder, hoping that that would force the line to be drawn. But the resulting FeatureWriter is still not creating a line dataset - it creates a dataset, but with no geometry.
Any ideas?
Thanks,
Stuart
geomancer
Forum|alt.badge.img+71
  • Dec 23, 2024 2:55 PM UTC
When I try a quick test with two boxes the line between the two polygons is formed correctly.
So I wonder about the two polygons you input. Are the coordinates that both polygons should share really the same?
scarter
  • Dec 23, 2024 3:22 PM UTC
​@geomancer, this is the Above polygon…
This is the Below polygon…
If shown together you can see that they match along the shared edges…
birgit
Forum|alt.badge.img+25
  • Dec 23, 2024 3:43 PM UTC
Can you show us the result of your LineBuilder in the inspector with the geometry and the points it consists of in a screenshot? Like so:
geomancer
  • Dec 23, 2024 3:45 PM UTC
I cannot be sure both polygons match along the shared edges. There could be small gaps and overlaps, there could be missing points, there could be differences of a millimeter between coordinates, there could be plenty of reasons why the edges of both polygons don't excacty match.
scarter
  • Dec 23, 2024 3:47 PM UTC
Here you go, ​@geomancer
geomancer
  • Dec 23, 2024 3:52 PM UTC
Can you show the information under Geometry in the Feature Information panel?
scarter
  • Dec 23, 2024 3:53 PM UTC
​@geomancer I’m confident that the polys do match along the main edge. I know this because the Below poly was created from the Above one. To do this I first created a doughnut polygon using the Above polygon (thus created a large poly with the area covered by Above as the hole in the middle). I then snipped it at the edges to create the Below polygon.
geomancer
  • Dec 23, 2024 4:13 PM UTC
I see. In that case, unfortunately I have no idea why your workflow does not produce a geometry, while my quick test does.
Maybe you will have better luck using a TopologyBuilder?
liamfez
Forum|alt.badge.img+44
  • Dec 23, 2024 8:30 PM UTC
Can you test with a GeometryFilter that the feature is a line.
And then for the writer, what is the writer format? You may want to check to ensure the geometry aligns (not trying to insert a line feature to an area featuretype that already exists).
