Input on how to make lines inside of building footprints
  • May 23, 2024 10:05 AM UTC
  • 220 views
jonnasemail
Forum|alt.badge.img+7
I’m working on a script that takes building footprints and outputs different lines inside them (crosses, diagonals, centerlines) depending on the type of building. I have achieved good results for square buildings and buildings that only require a centerline. See picture below.
But when it comes to buildings with more complicated shapes it doesn’t work as well. Some buildings turn out acceptable, like these ones below:
But some shapes turn out pretty bad, like the ones below:
I’d rather that they would look something like this:
I guess I would have to make the buildings into separate polygons to achieve these results, if it’s even achieveable. Does anyone have any ideas? I’ll attach a copy of my script
danilo_fme
Forum|alt.badge.img+58
  • May 26, 2024 2:39 AM UTC
Hi @jonnasemail
Please, could you share us your source data?
nielsgerrits
Forum|alt.badge.img+67
For most pieces, I would just use an oriented boundingbox (boundingboxreplacer). But for the L shaped polygons you’ll need to come up with something different.
jonnasemail
  • Jun 3, 2024 1:30 PM UTC
Hi @jonnasemail
Hi, here’s the source data attached.
jonnasemail
  • Jun 3, 2024 1:31 PM UTC
Exactly, if they were more or less square a bounding box works great. But when there’s indents and more angles it does not work as great because then the crosses will get cut weird.
