Indentation issue MSWord
  • Nov 28, 2019 10:39 AM UTC
  • 71 views
Hi, I'm using MSWord Styler to generate a word document in FME desktop. I have a paragraph which I need indented but it has parameters within which can vary in length. Hence line could spill over and does not keep the indentation. Anyone else have this issue? See example of issue below. thanks.
Example
Paragraph construction :
Instructions : Please note if any problems using this application, please contact <Name> <Dept>
for assistance. It is compulsory to use this application going forward for all customer orders
and inquires.
Output as :
Instructions : Please note if any problems using this application, please contact Joe Bloggs, Department of Finance
and inquires.
  • Nov 28, 2019 10:41 AM UTC
Apologies, example lost indentation!!
Example
and inquires.
Output as :
and inquires.
debbiatsafe
Forum|alt.badge.img+24
Hi @jwcc
I'm not certain if I understand your requirements correctly but it sounds like you want to create a paragraph that is entirely indented?
If this is the case, then I would recommend creating a base Word file that has an indented style and specifying this base file in the Base Microsoft Word File parameter in the Word writer. In the MSWordStyler, please specify the indented style. The paragraph you are adding should be indented as specified by the base Word document style.
I have attached an example workspace that demonstrates this approach. indentedparagraphword.fmwt
In this example I modified the Normal style to be indented 1cm on the left and specified the font to be 12pt Times New Roman. In the MSWordStyler, I specified the Normal style to be used.
I hope this helps.
