Increase the width of the ROUTE FEATURE accordingly based on the NO_OF_WAYS ATTRIBUTE
  • Jan 23, 2018 4:00 PM UTC
  • 62 views
Hi @mark_1spatial
I'm using Template.DWG file to define the Linetype for the ROUTE feature, i will need to increase the width of the ROUTE based on the NO_OF_WAYS Attribute(Below is the table mapping). Please let me know how i could achieve this in FME Desktop 2016. In attached file i should have the ROUTE feature width to be increased to 0.8mm so that the 5 cables(4 Low Voltage Cables-Orange color, 1 High Voltage cable-Red color) should be shown as going inside the ROUTE.
NO_OF_WAYS Width (meters on the ground) 1 0.3 2,3 0.55 4,5 0.8 6,7 1.05 8 1.3
Any help would be much appreciated.
Regards, Anil Kumar K B
erik_jan
Forum|alt.badge.img+26
  • Jan 23, 2018 4:42 PM UTC
The Bufferer or GeographicBufferer transformer could do this.
The difference between the two is that you can set units on the GeographicBufferer.
  • Jan 24, 2018 3:10 PM UTC
Thank you @erik_jan, GeographicBufferer transformer has done my Job. Thank you very much.
