I want to write the atrributenames of afeature to excel (vertical order). Can someone please help me?
  • May 22, 2017 2:20 PM UTC
  • 72 views
gio
Forum|alt.badge.img+15
  • May 22, 2017 3:35 PM UTC
read the schema (schema reader) and create a attribute and set its value to _attribute_name.
ciarab
Forum|alt.badge.img+10
  • May 22, 2017 10:14 PM UTC
Try the attributeexploder that will give you a vertical list of your attribute names and values.
jneujens
  • May 23, 2017 1:14 PM UTC
If you want more control on what attributes are written to excel, a really handy custom transformer can be found on the hub: the AttributeListExploder (https://hub.safe.com/transformers/attributelistexploder)
It does pretty much what the regular AttributeExploder does, but it stores a list of all the attributenames and -values. When exploding this list, you can use the index of this list to link it to the 'row number attribute' parameter in the excel writer.
  • May 23, 2017 4:40 PM UTC
Thank you very much. It works perfectly.
