I want to create a sequence of numbers starting from 1 but ending at a certain point which it will decide from attribute value coming from the SQL executor, suppose the value came out as 100, then I would want to create sequence of numbers upto 100.
  • Jul 1, 2021 2:42 PM UTC
  • 155 views
bhavyagandhi
I want to create a sequence of numbers starting from 1 but ending at a certain point which it will decide from attribute value coming from the SQL executor, suppose the value came out as 100, then I would want to create sequence of numbers upto 100. How ?
  • Jul 1, 2021 3:00 PM UTC
If you want a separate feature for each number of the sequence, then look at the Cloner.
bhavyagandhi
  • Jul 2, 2021 10:34 AM UTC
Thank you, can it be done via making a custom transformer using counters? I was trying out that way
  • Jul 2, 2021 12:20 PM UTC
Will the Cloner not work for your use?
bhavyagandhi
  • Jul 2, 2021 5:00 PM UTC
worked, but was trying another method
