I want to add a datum transformation, but I do not succeed
  • Jun 29, 2020 2:28 PM UTC
  • 5 replies
  • 106 views
Hello,
I want to add a cus datum transformation. But it is not working.
I have created this and saved in the shared folder:
DATUM_DEF Pulkovo1942\\
DESC_NM "Pulkovo 1942"\\
SOURCE "BP"\\
ELLIPSOID KRASSOW\\
XFORM_DEF WGS84_Pulkovo1942_Periplus_Test\\
DESC_NM "Pulkovo 1942, 7 parameter"\\
SRC_DTM WGS84\\
TRG_DTM Pulkovo1942\\
SOURCE "BP"\\
GROUP "PERIPLUS"\\
INVERSE Yes\\
MAX_ITR 8\\
METHOD 7PARAMETER\\
DELTA_X -686.10\\
DELTA_Y 123.50\\
DELTA_Z 574.4\\
ROT_X -8.0450\\
ROT_Y 23.366\\
ROT_Z -10.791\\
BWSCALE 2.926\\
COORDINATE_SYSTEM_DEF PULKOV1942_TM\\
GROUP "PERIPLUS"\\
DESC_NM "Pulkovo1942-PeriPlus"\\
SOURCE "BP"\\
DT_NAME Pulkovo1942\\
PROJ TMAF\\
UNIT METER\\
PARM1 09\\
SCL_RED 1.0\\
ORG_LAT 0\\
X_OFF 500000\\
Y_OFF 0\\
Please, can you help?
Best answer by daveatsafe
Hi @jjcdejong,
The seven parameters in the transformation are fine, but the coordinate system definition should have the projection set to TM, rather than TMAF. Please try changing this and re-running the conversion.
daveatsafe
Forum|alt.badge.img+24
  • Jun 29, 2020 3:50 PM UTC
Hi @jjcdejong,
The projection TMAF in your coordinate system is for transverse mercator plus an affine, which requires 7 parameters to be supplied. I think you want to use the TM projection, which only requires the single parameter for central meridian.
  • Jun 30, 2020 12:27 PM UTC
Hi, thanks for your reply. I do need to use these 7 parameters beacuse they vary slightly from the default values. And therfor the result is slightly different than required.
The problem is first that I do not see my coordinate system when I browse for them in FME.
And I am not sure if my definition as shown above is correct.
Thank for your help!
daveatsafe
  • Jun 30, 2020 3:47 PM UTC
Hi @jjcdejong,
  • Jul 1, 2020 10:27 AM UTC
Hi @jjcdejong,
I have changed my system definition. But it does not come up when I browse foor coordinate systems. Do you have any idea why this might be?
daveatsafe
  • Jul 2, 2020 3:20 PM UTC
Please remove the '\\' from the end of the last line of the datum, transformation and coordinate system definitions. The '\\' is a line continuation character, to make each definition effectively a single line.
