I have two tabels (please see attached image), and I would like to do the following: If ID(table 1) = Connection (table 2) fill this ID from (table 1) as a New ID attribute in (table 2) anyone can help? Thanks is advance!
  • Jan 9, 2021 8:37 PM UTC
  • 74 views
Best answer by danilo_fme
Hi @jassmin​
I tested again your case with the transformer FeatureJoiner and the results are positiv:
Workspace_ExcelAttached the Workspace template ( FMWT ).
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Jan 9, 2021 11:23 PM UTC
Hi @jassmin​
I suggest you use the transformer FeatureMerger to merger the attributes.
Thanks in Advance,
Danilo
danilo_fme
  • Jan 9, 2021 11:37 PM UTC
Hi @jassmin​
Thanks in Advance,
Danilo
  • Jan 10, 2021 8:24 AM UTC
Hi @jassmin​
Thanks in Advance,
Danilo
Hello,
I tried it. Works just fine! Thank you so much!👌
danilo_fme
  • Jan 10, 2021 3:19 PM UTC
Hello,
Nice @jassmin​ Thanks your feedback. I'm happy to help you!
