How to target specific subfolder when Upload file using S3Connector transformer?
  • Apr 11, 2022 7:04 PM UTC
  • 221 views
I've successfully made an S3 Web Connection and can write a file to a specific S3 bucket. I'm not seeing how to send the a file to a specific folder within the bucket using the S3Connector transformer settings. See attached screenshot. I have the Request Action set to "Upload."
There are input fields for Bucket and Path. I want to upload a file to my bucket "testBucket" and place the file in a subfolder named "Files" that's in a project specific folder named "$(projectName)." In S3 that's testBucket > $(projectName) folder > Files folder > file.png
As it is, the Bucket input has to match the S3 bucket name you are uploading to, but it also creates a new folder with your bucket name, and the Path input creates a subfolder within that bucket. In S3 that's testBucket > testBucket folder > $(projectName) folder > file.png.
Any suggestions on how to target testBucket > $(projectName) folder > Files folder > file.png?
Best answer by osdev
Thanks @chrisatsafe​ . I had a support ticket out on this and we just found out that the Amazon S3 Compatible Storage Web Service in Web Connections has an issue with saving a file to a specific folder path in S3, even if you type the path correctly as you have shown. I switched to using the Amazon Web Services Web Service, which can also be used by the S3Connector transformer, and using the path description you pointed out, it works now!
chrisatsafe
Hi @osdev​,
The easiest way would likely be to create a new, temporary attribute and set the value to this:
$(projectName)/Files/
This will allow you to set the path parameter in the S3Connecter based on the new attribute:
imageYou can also do this with a  published and private parameter in case you don't want to create an attribute.
  • Apr 19, 2022 5:45 PM UTC
