How To Switch Workflow Base on the Attribute Valye
bhk
Forum|alt.badge.img+3
Can you please let me know how I can switch and select the workflow based on the value of Attribute? For example I need to select and continue between continuing PythonCaller or PythonCaller_2 based on the value of operation
IF ‘operation’ == ‘ADD’ THEN Continue with PythonCaller
IF ‘operation’ == ‘REMOVE’ THEN Continue with PythonCaller_2
Best answer by panda
I think you can add TestFilter after attribute manager with the logic you need and connect output of each one to python caller accordingly.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
panda
Forum|alt.badge.img+18
  • April 7, 2025
Forum|alt.badge.img+50
Yes, that’s pretty much it.
