How to set username& password prompts for Database Connections in FME workflow ?
  • December 22, 2017
  • 5 replies
  • 100 views
dilipsebastian
jeroen
Forum|alt.badge.img+15
  • December 22, 2017
Is it not possible to change the values from this connection in the navigator to user parameters? Edit:
dilipsebastian
I did see few related articles mentioning this approach. Unfortunately, I don't see these Parameters options both in my reader as well as the Database Connection.
fmelizard
Forum|alt.badge.img+19
  • December 22, 2017
Hi @dilipsebastian, you should be able to create a private parameter for your Oracle connection string. In that parameter, you can reference 2 public parameters that prompt the user for a username and password. Ex- $(username)/$(password)@//<host>:<port>/<SID>
You can read more about concatenating published parameters here.
dilipsebastian
Thanks for your valuable inputs TiaAtSafe and JeroenR .
Meanwhile I figured out what went wrong. Previously while creating Database Connection using "Add Reader as Resource", I kept choosing "Add Database Connection" from the Dataset dropdown. This was the reason why I wasn't able to see username and password as parameters. This time I chose "Embed Connection parameters" as the dataset choice, and I can now see username and pwd listed as parameters. I went ahead and created published user parameters for both and used them in the readers and transformers in my workflow.
Thanks Again.
fmelizard
  • December 22, 2017
Thanks Again.
Yes! Embed connection will let you do this. I don't know how I forgot that, but I'm glad to read that you've got it working!
