How to "Set the CSV File Definition"
  • Sep 14, 2018 3:19 PM UTC
  • 50 views
Hi Tia,
I try to follow your post about "Sharing Published Parameters', then at step 3 Add the Writers, I cannot find where to "Set the CSV File Definition", did I missing something? Thank you and sorry to ask basic question.
Best answer by hollyatsafe
Hi @allensong,
You set the CSV File Definition in the wizard that appears before you have actually added the Writer to the canvas:
It is usually Copy from Reader by default. If you are not sure you can check this by clicking on the arrow to the right side of both the Reader and Writer names, the list should consist of the same attributes if the writer definition was set to copy from reader.
  • Sep 14, 2018 3:51 PM UTC
Hi @allensong,
