How to runarcpy scripts
  • Oct 31, 2018 4:25 PM UTC
  • 94 views
Hello,
I would like to run simple maintenance arcpy scripts on feature classes after a load. Without reading those feature classes.
Example of scripts: attribute index, spatial index, extent calculation:
arcpy.AddIndex_management(in_table="C:/Users/xxx/Documents/ArcGIS/Default.gdb/tablename", fields="Name", index_name="name_1", unique="NON_UNIQUE", ascending="NON_ASCENDING")
arcpy.RecalculateFeatureClassExtent_management(in_features="C:/Users/xxx/Documents/ArcGIS/Default.gdb/tablename")
For both file geodatabase feature classes and Enterprise Geodatabase.
How do I achieve this with either a shutdown python script or PythonCaller / Creator?
Thanks
Best answer by oscard
Take a look at this article: https://knowledge.safe.com/articles/47216/using-arcpy-for-fme-feature-processing.html
I guess you will need to change your Python interpreter to the one that has the arcpy module
oscard
Forum|alt.badge.img+23
  • Oct 31, 2018 4:44 PM UTC
  • Oct 31, 2018 5:24 PM UTC
Hi @oscard
Thanks a lot, I was able to make it work. Is there any way I can be switching to the custom interpreter with a script or some command before running the translation and then set it back to default after the translation?
Thanks,
debbiatsafe
Forum|alt.badge.img+24
Hi @oscard
Thanks,
Hi @honkovam
How did you change the Python interpreter in your workspace? If you used the workspace's Python Compatibility parameter (eg. set to Esri ArcGIS Desktop Python 2.7), no further action should be required as changes to this parameter only applies to the current workspace.
Edit: This applies to FME 2017 and 2018 only
