How to retrieve formate attribute value direction from AreaBuilder
  • Jan 30, 2016 11:41 AM UTC
  • 58 views
sveinj
Forum|alt.badge.img+3
I use RadiateLineGenerator, Intersector and AreaBuilder to produce a sector diagram. I have problems getting the values into the sectors. By building list in AreaBuilder all the attributes from the intersector is preserved in the list. The problem is that I dont know which of the list elements to use.
AreaBulider generates a format attribute named direction (along with fme_gemetry and fme_type). If I test on the value of direction ('same' or 'opposite') I can find the correct element in the list. How can i retrive then vaule of a format attribute?
pratap
Forum|alt.badge.img+12
  • Feb 1, 2016 10:20 AM UTC
Have you tried AttributeExposer?
Pratap
gio
Forum|alt.badge.img+15
  • Feb 1, 2016 4:11 PM UTC
better way to create diagram (?):
1. count records holding values.
2. create a line of length of choice and (starting) location of choice.
3 duplicate by number founds at 1.
4 rotate lines by (totalvalue/value)*360 (or 2pi)
5 create 2darc with lenthg used at 2 at location used at 2.
6 intersect them.
7 build area.
8 colour by copynumber or value using featurecoloursetter.
9. label as desired using centerpointreplacer.
Maybe 2D affine labelpoint by:
x= 1,0,(angle of centerline of sector)* (length used at 2 + someoffset)
y = 0,1,(angle of centerline of sector)* (length used at 2 + someoffset)
AS radialgenerator will only create constant radials...
Put all in a custom and make input generic (use paramaters... then you too can maybe post it to the shop?)
