how to remove duplicate id at Attribute to Concatenate at the aggregator transformer
  • May 16, 2020 8:08 PM UTC
  • 7 replies
  • 344 views
gogopotter90
Forum|alt.badge.img+14
i would like to aggregate the data
so i used Aggregator Group by Main unique ID
Attributes to Concatenate 3 Attributes name that i want to combine
but i found each row has one Attribute main ID, and many id at the first and second (Attribute to Concatenate ) duplicated more than one but the third not , my question : how could i remove the duplicate IDs inside the attribute to Concatenate , i need only the unique IDs only if dupliated .
i tried Duplicate filter but it does not work .
after i used the aggreator attribute to oncentate submain 1,submain 2 ,submain 3 the ouput looks like that ,i would like to delete duplicate in each row at eaach attribute
Main
submain 1
submain 2
submain 3
5
2,5,4,4,3,3,4
6,6,3,2,2,5,1,5
9,4,7,8,2
FME 2018
so what should i do ,thanks for help
becchr
Forum|alt.badge.img+35
  • May 16, 2020 8:28 PM UTC
hi @gogopotter90, for me it's not completely clear what you want to do exactly, can you share some small sample of your data to clarify?
Instead of using the aggregator to concatenate, click the check box for list and select the unique key, on the output from the aggregator use a ListDuplicateRemover on the list, then use a ListConcatenator to concatenate the keys.
For this example, DIVISION is my attribute I'm using. Sort your records so it's in order.
List of duplicates
Duplicates removed
Concatenated records
gogopotter90
  • May 16, 2020 10:58 PM UTC
List of duplicates
Duplicates removed
THANKS FOR UR method ,but in my case i do not have only one attribute and list concentae as u eplained i have tried ,i believe it is only to choose one attribute but at aaggregator ,i can choose more than attribute .
Main
submain 1
submain 2
submain 3
5
2,5,4,4,3,3,4
6,6,3,2,2,5,1,5
9,4,7,8,2
here it gives me relation between main and the another attribute ,in ur method can i get also relationship like here .so should i use two list duplicate remover for submain 1 and 2 or what should i do .
thanks
gogopotter90
after i used the aggreator attribute to concentate submain 1,submain 2 ,submain 3 the ouput looks like that ,i would like to delete duplicate in each row at each attribute
Main
submain 1
submain 2
submain 3
5
2,5,4,4,3,3,4
6,6,3,2,2,5,1,5
9,4,7,8,2
Main
submain 1
submain 2
submain 3
5
2,5,4,4,3,3,4
6,6,3,2,2,5,1,5
9,4,7,8,2
thanks
Got ya.
In the example below I take the 1 record with 3 attributes, split by their delimiter, remove duplicates, re-concatenate, and then merge them back into a single record by their unique key.
Maybe someone else has an example of a regex that can do the same thing.
Got ya.
gogopotter90
  • May 18, 2020 7:59 AM UTC
Got ya.
Thanks alot
