How to read the data from excel file from a directory
  • Jan 30, 2025 4:11 PM UTC
  • 128 views
pauline1985
I need your help.
I would like to read the data from an excel file that change every week.  Moreover the excelfile have a different name every week.
I would like to try to automate the process and as an input i would like to have the directory instead of the file.
How can I do that?
Thank you for your answer.
Pauline
hkingsbury
Forum|alt.badge.img+73
  • Jan 30, 2025 8:09 PM UTC
An old article, but still relevant - http://docs.safe.com/fme/2013/html/FME_QuickTranslator/content/fme%20configuration/dataset_wildcards.htm
You can use wildcards in your paths to read everything in a folder
pauline1985
  • Feb 6, 2025 2:44 PM UTC
Thank you for the article.
Where should i use the wildcards? in a reader excel?
Thank you.
pauline1985
  • Feb 7, 2025 9:38 AM UTC
I find it!
