How to read one geometry from multi-geometry table ?
  • August 28, 2020
  • 49 views
lifalin2016
Forum|alt.badge.img+29
In MS/SQL I have a table with multiple geometry fields. When using a FeatureReader, how can I designate which geometry column to read ?
Best answer by david_r
I believe you'll have to check the option "Handle multiple spatial columns" on the reader. You can then select the geometry column by filtering on the traits in the resulting aggregate, see also the documentation:
http://docs.safe.com/fme/2020.1/html/FME_Desktop_Documentation/FME_ReadersWriters/mssql_spatial/MSSQL_Spatial_reader.htm
  • August 28, 2020
