How to read all tab in ACC using AutodeskBIM360DocsConnector?
  • May 10, 2023 12:26 PM UTC
  • 29 views
arthy
Forum|alt.badge.img+8
I would like to be able to read other tab in ACC.
Right now the AutodeskBIM360DocsConnector transformer returns only the list of files within a project which correspond to the first tab. I can't read the other tabs such as reviews or Issues
@david_r​ , @andreaatsafe​ , @Takashi Iijima​  and others , any ideas?
  • May 11, 2023 7:52 AM UTC
The AutodeskBIM360DocsConnector can only work with the files on ACC/BIM360. For everything else, you'll have to use the HTTPConnector (or rather, a series of them) to go through the corresponding API:
https://aps.autodesk.com/en/docs/acc/v1/overview/
If you are somewhat fluent in Python that's what I'd recommend, however.
