How to re-organize a table using numbered attributes
  • Sep 11, 2018 12:39 PM UTC
  • 72 views
olivier
Forum|alt.badge.img+7
I have a table which is using numbered attributes such as the following (this is a fictitious simplified example):
Id Description LanguageCode0 NotationAlphabet0 NameText0 LanguageCode1 NotationAlphabet1 NameText1 LanguageCode2 NotationAlphabet2 NameText2 1 Park1 FRE Latin Parc Vert DUT Latin Groenpark ENG Latin Green Park 2 Park2 FRE Latin Parc Rouge DUT Latin Roodpark ENG Latin Red Park
In the above situation each park has 3 names, one for each language (FRE, DUT or ENG)
And I need to re-organize it in such a way that it looks like the following:
Id Description LanguageCode NotationAlphabet NameText 1 Park1 FRE Latin Parc Vert 1 Park1 DUT Latin Groenpark 1 Park1 ENG Latin Green Park 2 Park2 FRE Latin Parc Rouge 2 Park2 DUT Latin Roodpark 2 Park2 ENG Latin Red Park
I have tried to achieve this with a ListExpressionPopulator or using the ListPopulator. With the first solution I can get everything into one list but I lose information on the attribute name (LanguageCode, NotationAlphabet,...). Using the ListPopulator it seems this will lead me to having a distinct list for each attribute. But then how can I merge multiple lists into one, keeping in mind that there could be quite many attributes in my real table.
Or do you see other ways of transforming this table?
Thanks in advance for your suggestions!
Olivier
Best answer by takashi
Magical regex!
  • Sep 11, 2018 12:58 PM UTC
Magical regex!
olivier
  • Sep 11, 2018 1:09 PM UTC
Fantastic! Thank you so much @takashi ! This is a very elegant solution to my problem. :-) I had overlooked the power of the BulkAttributeRenamer.
