How to pass a user parameter to a custom transformer and used in a pythonCaller?
  • Aug 29, 2019 8:18 PM UTC
  • 436 views
How does one pass a user parameter to a pythonCaller that's inside a customTransformer
import fme
import fmeobjects
def processFeature(feature):
    p = FME_MacroValues['SomeUserParameter']
    print p
I read here "If you put your pythonCaller inside a custom transformer, the parameter name changes to {customTransformerName}_SomeUserParameter. "
I tried then doing this below but still does not work.
import fme
import fmeobjects
     p = FME_MacroValues['{customTransformerName}_SomeUserParameter']
     print p
What am I doing wrong?
  • Aug 29, 2019 8:44 PM UTC
Try to put a ParameterFetcher in the Main part of the workspace and fetch your user parameter. Then go into the custom transformer, open the settings for the Input and expose your parameter.
jdh
Forum|alt.badge.img+41
  • Aug 29, 2019 9:24 PM UTC
It's not the custom transformer name, it's the custom transformer instance name, so if you have two instances of the custom transformer, the MacroValues are going to be different.
It's much better to use a parameterFetcher inside the custom transformer to store your parameter as an attribute, and then reference it by feature.getAttribute('_ParamAttr'). This will be consistent no matter how many times the custom transformer is used, or renamed.
lifalin2016
Forum|alt.badge.img+42
  • Mar 3, 2023 10:17 AM UTC
This is the sensible approach. The parameter naming inside custom transformers is horrible. Fortunately one can easily clean up all the internal attributes when outputting features from the transformer.
jdh
  • Mar 3, 2023 2:33 PM UTC
All my temporary attributes inside a custom transformer begin with ! so they are exceedingly unlikely to conflict with existing data, no matter who is using the custom transformer.
Even better is to use a specific prefix for each custom transformer. ex !GAC_ for GeographicalAreaCalculator.
