How to group row in excel based on a common value in column?
  • Jun 29, 2020 2:29 PM UTC
  • 159 views
I want to add <Name> together which can be opened and closed in Excel (visual compress), so i can see the different attributes for the same <Name> when opening the label. Does anyone know how we can use this in Excel? In the attachment is an example of how the <Name> value should look like.
@daveypoot I haven't used Outline/Groups in Excel. You might be able to use them if you configure your Outline in Excel and then use that as a template.
