How to geocode with my own adress database
Hi there,
I'm a bit helpless after trying the hole day. Well, what is my problem. Let me try to describe it.
I have a huge amount of adresses, consisting of postcode, town, district, street, hous no, coordinates etc. I concatenated all to a adress-string. Saved in a Geodatabase.
Now I'm trying to geocode some adresses, by comparing with the adress-strings in the database. This is not the problem, i can do this but it takes a long long time.
Now, my idea was to send every single adress with the workspacerunner to a new workbench, where I filter the Reader (my adress database) by using the Where clause to a district. Result of this should be, that fme only have to compare the adresses of a district and not all adresses. I can't compare for 1000 adresses with my database this takes too long.
Well, nice idea, but I can't use a user paramater in the Where clause in my Reader, is this correct?. I tried it by transfering the district from the adress via the workspacerunner and userparameter. Where clause: district=$(district)
Any idea how I can solve this?
bruceharold
Forum|alt.badge.img+17
  • August 10, 2017
If you have ArcGIS then create a geocoding locator and geocode in ArcGIS.
courtney_m
Forum|alt.badge.img+12
  • August 10, 2017
You can set the where clause on the Feature Type. If you click on the down arrow next to WHERE Clause: you can open the Text editor, and use the attributes and parameters listed on the left side of the dialog to create your where clause.
  • August 10, 2017
Thanks for your answer, but this is not working. Where clause was district=$(district) but seams not to work with a user parameter. In my case it's working with a real district like district='abc' but not with the user parameter.
courtney_m
  • August 10, 2017
@dmasl, did you try it with quotes around the parameter name? district='$(district)'
  • August 10, 2017
Unfortunately, not. The only professional Geotool that I can use is FME.
  • August 11, 2017
Use a FeatureReader rather than a classic reader, it's much more flexible.
courtney_m
  • August 11, 2017
@dmasl, in case you did not see my response to my existing comment below, I wanted to add it here. When you modified the where clause, did you try it with quotes around the parameter name? district='$(district)'
You need to use the quotes to specify that the parameter value should be read as a string.
-Courtney
