How to fix an TypeError: descriptor 'runWithParameters' error?
  • Aug 29, 2016 2:52 PM UTC
  • 91 views
I have just tried to use the snippet supplied by Safe to run a Workbench from python and i get the following error
TypeError: descriptor 'runWithParameters' requires a 'fmeobjects.FMEWorkspaceRunner' object but received a 'str'
This is my code so far up to the point where these is the error:
#initiate FMEWorkspaceRunner Class
runner = fmeobjects.FMEWorkspaceRunner
#Full path to Workbench
workspace = r'C:\\Avoidance_Areas\\shape2acad2016.fmw'
#Set workspace parameters by creating a dictionary of name value pairs
parameters = {}
parameters['SourceDataset_SHAPE'] = Avoidance_Area_shp
parameters['DestDataset_ACAD'] = r'C:\\Avoidance_Areas\\Avoidance_Areas.dxf'
# Use Try so we can get FME Exception
try:
# Run Workspace with parameters set in above dictionary
runner.runWithParameters(workspace, parameters)
Can anyone tell me why its having this issue as im following the supplied code template.
Best answer by david_r
Try with paranthesis at the end:
runner = fmeobjects.FMEWorkspaceRunner()
They are the difference between returning a class reference (without paranthesis), and returning an instance of the class (with paranthesis).
Notice the paranthesis here as well.
  • Aug 29, 2016 3:21 PM UTC
  • Aug 31, 2016 4:08 AM UTC
Thanks David - looks like that helped but now im getting the
FMEException: 896902 ... i will have to inveistgate why this is the case.
