How to expose file name as fme_feature_type attribute value
  • Jan 3, 2018 9:56 PM UTC
  • 12 replies
  • 1016 views
marsh007
Forum|alt.badge.img+11
I'm using FeatureReader as CSV format and trying to expose attribute 'fme_feature_type'. It's returning NULL or CSV. Instead it has to return FILENAME.
Any thoughts please?
Best answer by rylanatsafe
@fmeuser_gc - Try using an AttributeManager after the FeatureReader to create a new attribute that references fme_feature_type as the value. I've attached a workspace template created using FME 2017.1.2 Build 17722 that demonstrates this.
The fme_feature_type remains null, but my new attribute _fft is populated and writes out correctly (using native CSV Writer).
Hope this helps!
fme-feature-type-2017.fmwt
Edit: The display issue with fme_feature_type values in the FME Workbench Canvas and FME Data Inspector is no longer observed with FME 2018.0 Build 18240 or Newer.
Hi @fmeuser_gc
Try fme_basename or fme_dataset as the attribute to expose instead.
Whatever the brown feature type on the canvas is saying, that's the attribute value you'd get when using fme_feature_type.
marsh007
  • Jan 3, 2018 10:04 PM UTC
Hi @fmeuser_gc
Hi @jlutherthomas, no it still returns NULL values.
erik_jan
Forum|alt.badge.img+26
  • Jan 3, 2018 10:10 PM UTC
I have seen this before, but only in the Data Inspector (version of the transformer is 5, works OK with version 4).
If you write the data to an output format, does it still remain NULL?
In my case it showed the file name in the output, but not in the Data Inspector, even though it was exposed.
marsh007
  • Jan 3, 2018 10:16 PM UTC
Hi @erik_jan, I get nothing in both Data inspector and Output format.
Can you expose it using the AttributeExposer rather than on the feature type?
marsh007
  • Jan 3, 2018 10:24 PM UTC
It still returns defalut 'CSV' value. Actually looking for name of file
rylanatsafe
Forum|alt.badge.img+14
  • Jan 3, 2018 11:52 PM UTC
Hope this helps!
Have you tried exposing fme_basename or fme_dataset instead of fme_featuretype? The feature type is CSV in your case, so you need a different attribute
marsh007
  • Jan 4, 2018 6:12 PM UTC
Hope this helps!
Hi @RylanAtSafe, this worked. I've just changed the Feature Type Name(s) for Dataset parameter as there is no 'AttributeManager' transformer in 2015.1 version.
Thank You for your reply.
marsh007
  • Jan 4, 2018 6:13 PM UTC
Hi @jlutherthomas, this is useful info for sure. Thank You.
rylanatsafe
Glad to hear it! Thank you for following up here.
