How to Expose Attribute Iteration Count in a loop
  • January 29, 2020
  • 5 replies
  • 401 views
jelle
Forum|alt.badge.img+23
I have a Custom Transformer with a loop in it. It contains Blocking Transformers, so it is linked. I would like to pass the number of iterations to the main Workspace, but I do not find how to expose the Attribute that I have set in the Advanced properties of the Custom Transformer:
the only reference that I found is: https://knowledge.safe.com/questions/4722/accessing-iteration-coutn-parameter-is-it-possible.html of @gio. Do you remember how you solved it in the end? Thanks in advance.
Best answer by gio
the iteration count is a parameter, it says attribute to hold etc... but this is only "External" not "within" the custom you make. Within it is a (published) parameter.
So there is no exposing, you need to fetch the parameter into a attribute.
Betst to set a sampler = 1 after the creator (or parameterfetcher) as you need the information only 1X (not X nr.of feature)
Also sampling will show the iteration count on the feturecoutn (see bottom pic).
Here is a screencap whilst running...at 4th iteration
This is inside the custom.
The bottom custom output is for the ICA.
It is even possible to drive the iterationcounter by expression. In this case it was the reason i incorporated it in this custom.
The examples are from my "IterativeNeighbourFinder_2_2_2".\\
Here is output on a 10 iteration run
See the ica, sarting at missing of course. Showing runs finsished.
Forum|alt.badge.img+53
  • January 29, 2020
Have you tried just using the AttributeExposer? If i set the attribute it's created but not exposed
jelle
  • January 29, 2020
Yes, that is the first thing I tried. The value remains on <missing>
gio
Forum|alt.badge.img+15
  • January 30, 2020
gio
  • December 2, 2020
@Jelle De Zwaef​
Ji.
Here is a custom setup that exposes it.
I used the ICA te create variable search steps. (using ICA as variable in equations)
It is a blockint custom in a custom.
Its a iterative neighborfinder.
Greets.
gio
  • December 2, 2020
Addendum
I see i posted this already. I respondend to FEM forummail
You have to take care not to enter expressions in the custom input.
Else it will lead to PArameter invoked etc. error.
