how to execute FME workbench with parameters in java
  • Oct 10, 2018 1:20 PM UTC
  • 170 views
I am trying to run FME workbench with input and output file destination and directory. This workbench is copying file from one directory and pasting in another directory.
I tried with different methods of IFMEStringArray but doesn't seem to work and I can't find documentation on the internet.
IFMESession createSession = COM.safe.fmeobjects.FMEObjects.createSession(); IFMEWorkspaceRunner createWorkspaceRunner = createSession.createWorkspaceRunner(); IFMEStringArray createStringArray = createSession.createStringArray(); createStringArray.append("C:\\\\test\\\\test.csv"); createStringArray.append("C:\\\\test2"); createWorkspaceRunner.runWithParameters("C:\\\\test\\\\Initialization_VIC_DataSet.fmw", createStringArray);
Above is my code. Can someone please help?
Best answer by fmelizard
Hi @gaurav14u.
There's a sample Java app that demonstrates use of IFMEWorkspaceRunner in FME_HOME\\fmeobjects\\samples\\Java\\GeometryViewer so that might give you the jump start you need.
There's also a Python IFMEWorkspaceRunner sample if you prefer that route: FME_HOME\\fmeobjects\\samples\\Python\\WorkspaceRunner
fmelizard
Forum|alt.badge.img+22
  • Oct 11, 2018 8:06 PM UTC
Hi @gaurav14u.
danilo_fme
Forum|alt.badge.img+58
  • Oct 13, 2018 2:36 PM UTC
Hi @gaurav14u.
Nice Documentation @NatalieAtSafe
