How to change Oracle SID post FME server installation?
  • Nov 21, 2019 10:41 AM UTC
  • 52 views
We have FME 2016 installed couple of years ago with an Oracle SID. Now with Oracle migration to cloud, our SID name has changed. post SID name changes, we are not able to login to FME server. Is there any way that SID can be changed and FME can be used again without reinstallation?
  • Nov 21, 2019 12:47 PM UTC
Is this for the internal FME Server database?
If so, have a look in the configuration file
<FMEServer>\Server\fmeCommonConfig.txt
Search for "DB_TYPE=oracle" to find the relevant section, you probably want to modify the value of DB_JDBC_URL with the new SID.
  • Dec 10, 2019 6:34 PM UTC
Thanks David, It helped
