How to append a value to a list?
  • February 13, 2017
  • 6 replies
  • 379 views
Hi!
I have a list, containing between 5 and 50 values (varying). How can I append a value to this list? I can only assume there has to be a non-pythonic way, but I struggle to find one. My approach was to use AttributeCreator, but I can't dynamically specify the position in the list. Had the list size been fixed, then that's a solution - but not in this case.
Any ideas?
Best answer by david_r
You can use the ListElementCounter to find the last position, which you can then use in the AttributeCreator. Example, assuming your list is called "list{}":
  • February 13, 2017
  • February 14, 2017
Of course! I didn't see it in the popup specifying "input a number" and didn't think of this manual way to do it. Good call - this should work.
However, I can't get it to "evaluate" properly? Instead, it creates an attribute called list{@Value(_element_count)}
  • February 14, 2017
Which version of FME are you using? I tested with FME 2016.1.3.1.
  • February 14, 2017
Okay, now it works here too. However, it also exposes an attribute called list{@Value(count)}, which confused me. Thanks, David!
  • February 14, 2017
Yes, the exposed list{@Value(count)} annoys us a bit.
For what it's worth, if you want to avoid to expose it, and also do not use Python, Tcl scripting would be an alternative. Assuming an attribute called "_newValue" stores the new value to be appended to the "_list{}".
Tcl Expression for a TclCaller
FME_SetAttribute _list{[FME_Execute NumElements _list{}]} [FME_GetAttribute _newValue]
FME Function call in an FMEFunctionCaller
@Tcl2("FME_SetAttribute _list{[FME_Execute NumElements _list{}]@Value(_newValue)")
YES, I know you don't like to use Tcl, @david_r ;-)
syedh2993
Forum|alt.badge.img+5
  • December 31, 2024
Hi All,
I am working with lists and require some guidance on the below scenario
I have list which contains 'n' elements. I would like to add a sub-element to each element in the list.
Assuming my list name called as "list{}"
Example: (My list currently looks like this)
    List{0}
        element1
        element2
        element3
    List{1}
        element1
        element2
        element3
    List{2}
        element1
        element2
        element3
    List{n}
        element1
        element2
        element3
I would like to add new sub-element called "element4" at the end of each list element (i.e., add "element4" as sub-element below "element3" )
Expected Output (I would like to achieve something like below)
    List{0}
        element1
        element2
        element3
        element4
    List{1}
        element1
        element2
        element3
        element4
    List{2}
        element1
        element2
        element3
        element4
    List{n}
        element1
        element2
        element3
        element4
Would really appreciate your help in achieving the above expected output.
Thanks
