how do I group and count the values in the csv file
  • Jun 24, 2020 5:23 PM UTC
  • 642 views
I can group and count attribute values from a table using sqlcreator
select a.CaseFullRef, count(a.casefullref) as count2
from bcapr as a
inner join bcinsac as b on a.SystemKey = b.systemkey
group by a.CaseFullRef
order by a.casefullref
This gives me the required output
But I need to compare this table with a csv file
I want to group and count the values in the csv file in the same way as the table . How do I group and count the attribute values in the csvfile ?
I tried using counter but it just adds a count to each incident of the value .how do I add group by to the counter?
Best answer by ebygomm
If you want to count how many occurrences of each CaseFullRef you want to use an Aggregator or a Statistics Calculator
e.g.
The inline querier is another option if you're familiar with writing sql
select CaseFullRef, count(1) as count from CSV_Input
group by CaseFullRef
Forum|alt.badge.img+54
  • Jun 24, 2020 6:02 PM UTC
e.g.
e.g.
Thank you . The aggregator does the job.
I am very familiar with SQL. Most of my Translations use SQLCreator . So I would like to get to understand the inline querier However my first attempt with this  and I am completely baffled by the  input and out put ports on this transformer.
Please could you  send me screen shots of how I would configure the  ports on the inline querier?
  • Jun 25, 2020 7:42 AM UTC
If you just want to perform an sql statement against one table as in the count example, you just simply link up your csv to the input port, this will populate the input with the table name and the column names and types.
You then create an output port with whatever name is sensible, and enter your sql query
Brilliant Thanks . This is going to save me a lot of time. I was importing csv's into the database , with all the issues of data types etc and querying in Studio manager.
Now I have better options I can use in FME.
Sorry to be so thick but I rarely understand the help on the transformers and so struggle to know how to use them. I very much work on the basis of copy and tweak someone else' s workbench examples.
Thanks again
Lizzy
