?How do I create this output? (In a writer: have an attribute with one value / other attributes with multiple values)
  • Feb 12, 2018 7:33 AM UTC
  • 7 replies
  • 80 views
Hi all,
I'm having a hard time describing the issue I'm facing so I'll just show what output I need.
I need two writers:
The first writer contains POI_NAME and POI IDs. (unique values)
The second writer should output the POI IDs found in the first writer but with two additional attributes TYPE / TYPE_VALUE that can hold various strings.
(Basically I have no clue on how to populate POI_ID with identical values but TYPE / TYPE_VALUE with different values)
Reader:
First writer:
Second writer:
Thanks,
Ed
oscard
Forum|alt.badge.img+23
  • Feb 12, 2018 7:46 AM UTC
Hi.
Could you tell us a little bit about the source data? It would be easier to help you if we knew the schema of the information you are reading.
  • Feb 12, 2018 8:06 AM UTC
Hi.
Hi @oscard ,
Thanks for the fast response. I can't show you the actual source data but it contains all data and the format looks like this:
In short the reader contains all data that needs to be written to two writers. Cheers,
Ed
oscard
  • Feb 12, 2018 8:14 AM UTC
An easy solution to get the second writer could be with two AttributeManager.
Join the reader with one of them:
- Keep POI_ID and SUBCAT.
- Create the attribute TYPE and give it the value "SUBCAT"
- Rename "SUBCAT" to "TYPE_VALUE"
Join the reader with the other one:
- Keep POI_ID and URL
- Create the attribute TYPE and give it the value "URL"
- Rename "URL" to "TYPE_VALUE"
Join both AttributeManagers with the second writer.
I think that should work.
  • Feb 12, 2018 9:00 AM UTC
Almost - but I'm getting duplicated values in the TYPE attribute... :-(
Did I do something wrong?
oscard
  • Feb 12, 2018 9:09 AM UTC
I guess you mean you are getting empty values for POI_ID and TYPE_VALUE in some rows.
I bet the reader is reading empty rows. Add a Tester after the reader:
- If "POI_ID" has value --> Passed
- Otherwise --> Failed (do nothing with the elements of this port)
  • Feb 12, 2018 9:18 AM UTC
The empty values are not in the reader so I've put the tester just before the writer - it works now!
Thanks for your help and fast response.
Best,
Ed
oscard
  • Feb 12, 2018 9:21 AM UTC
Best,
Ed
Glad to know you could resolve it :)
