How can I export 3D building, textures, and attribute from Revit 2017 using FME exporter for Revit to ArcScene?
  • Apr 12, 2017 2:39 PM UTC
  • 0 replies
  • 60 views
Hi, Could anyone please help me to transform the 3D object from Revit to ArcScene? I exported the 3D using FME exporter to get RVZ file, however, when I tried to visualize the result in FME data Inspector, the texture of the building wasn't appeared or transformed. I am not sure of the options I have to choose from the Export dialog to export the texture. Any Idea?
Also, I transformed the RVZ file as it is (without texture) using FME Workbench Desktop to Shapefile and I have noticed that the multipatch layers for the building didn't come/merge in one attribute in ArcScene, and of course the texture was not appeared as well.
Thank you,
