Help create a workflow that creates split KML files of efficient drone flight route between hundreds of points but avoids polygons
Hello all, I've been pointed into the direction of FME by someone on Reddit with the below query. Is anyone able to help me achieve this output of multiple KML files with a workflow in FME Desktop...
I've been provided with the location of a solar farm to fly over with my drone and a thermal camera. The CAD drawing of the solar farm has been geo-referenced and sliced into a tile layer: http://abovesurveying.s3-website-eu-west-1.amazonaws.com/Spriggs%20Farm%20v2_Thaxted_CAD/{z}/{x}/{y}.png
I have an app on the iPad that controls the drone that will point it north as a constant heading and fly from end to end of the solar panels. This is all achieved by uploading a KML file to the app. At the moment I manually create the KML files with LineString coordinates limited to 1.80 kilometers or 99 waypoints (whichever comes first). This is going to be extremely time consuming. So....
I have created three different KML files which are attached:
  • Launch locations. These will be different locations around the solar farm that are designated as safe to launch from.
  • Obstacles. These will be things like powerlines, tall trees, buildings, wind turbines, etc. This will be written into a KML file as Polygons (shapes).
  • Waypoints. These will be literally every single end of row of solar panels, the start point and end point of a pass along a row of panels.
I have created these files for the Spriggs location above to test.
Is there a way for FME to digest all this information and create the most efficient routes between all the points not exceeding the distance and waypoint limits or, flying over obstacles?
I'm looking for the output to be multiple KML files that cover the entire solar farm for flight. Each of these files is a section of the solar farm or a zone, call it what you will. Must be KML as that is what the iPad app for the drone accepts.
I can see an issue being that the example solar farm given has some ends of rows very close to others with a hedge row between them. So will the workflow that creates the output think that flying over the hedge is the correct survey area, or will it know that the other end of row is much further away? Or do I negate this problem and block out the hedge as an obstacle even though it is technically low enough to fly over?
Routes are east/west and west/east waypoints then traveling north/south or south/north to get to the next east/west west/east row of panels. The entire purpose is to make the output more efficient than what I could create manually and also speed up the process. I'm guessing my input data has to be pretty spot on.
Additionally I need each of these sections/zones to be listed in a table specifying which launch location they're using, their total distance in kilometers or meters and how many waypoints are within the flight. Distance and waypoint count to include the launch and landing as a waypoint and the distance to and from this location. This is because it is important the flight doesn't exceed the distance parameter set due to batteries not lasting much longer.
Any ideas on how to achieve this problem?
steveatsafe
Forum|alt.badge.img+12
@garymrowe My Colleague just published https://hub.safe.com/transformers/uavmissionplanner#.
This generates a CSV file. This might help you in your quest... but I don't think we have a limit on the flight time... however that could be built into it. Do you happen to happen to have access to the CAD files of the farm? Something that we could use to generate flight paths from?
I'm happy to look into this a bit more with the data you provided.
steveatsafe
PS: I'm assuming you are using the Litchi app - can you confirm?
  • July 18, 2017
Excellent, I am using the Litchi app yes. The txt file attached to my post has the link to the tileserver for that location which is the CAD drawing sliced up.
I look forward to having a play with the mission planner.
Flight time doesn't need to be limited, only the distance as I've calculated that from the time. Additionally the DJI SDK that Litchi uses limits waypoints to 99. So no flight can exceed that many waypoints.
I will report back further tomorrow when I've had a play.
  • July 18, 2017
Steve I'm really struggling as have no FME experience. I do not know how to get to the Mission Planner. It's installed but that's it.
steveatsafe
@garymrowe OK. I had a closer look at your data, particularly the waypoints file. Using the KML waypoints file, it would be possible to join these points in sequence if they were in sequence from start to end of the solar panel array in the KML file but they are not all sequential. Some of them are, but most are not. I've attached a screen shot of what current sequential file looks like.
The north part of the farm looks pretty good but no perfect.
If these waypoints where sequential we could output to the litchi csv file to start a mission (we could separate these out into separate mission files based on 99 way point limit or distance limit which ever came first).
That is one way.
Another way would be to see if we could use the CAD files of the solar farm. The Map Tile service does not produce vector. These are raster representations of the CAD files. Do you happen to know if you can get the CAD drawings? If we had these (Centre Lines of each array would be perfect) then creating the litchi CSV file would be pretty straight forward.
If you can't get the CAD file... it would be down to ordering the waypoints and then we could create sequential file that we could push to a consumable CSV file for the Litchi App.
@SteveAtSafe can you share a link to the demo workspace named on the link page for the Hub transformer please
steveatsafe
Hi @1spatialmary I've created a question to answer this: https://knowledge.safe.com/questions/48489/index.html
steveatsafe
Hi @garymrowe Here's the aforementioned workspace: https://knowledge.safe.com/questions/48489/index.html
