help batch process GIS to CAD
  • Jun 16, 2016 3:44 PM UTC
  • 68 views
Hello,
I want to export in DWG as "road_CC47" (voies_CC47) many shp files as it is show below.
I want to do an export of "road_CC47" for EACH neighbourhood but the shp files I use include all
the neighbourhoods of the city. I would like to repeat the process for each neighbourhood and that the file's name take the neighbourhood's name such as "road_CC47_1", "road_CC47_2", "road_CC47_3" ...
I don't know how to proceed? I thought I could use a sql query and a spatial filter that loop on the process but I really don't know how to do this in FME.
Could you help me please?
Thanks
Hugo
Best answer by gio
1. Relate the neighbourhood to the roads using a spatialrelator, areaonareaoverlayer or clipper. This adds the attribute to all the roads.
2. Create a autocad writer.
3. In het navigatorpanel (left) go to parameters=> advanced=>"Attribute to fanout on"
Set this attribute to neighbourhood attribute u set at 1.
clear/empty the "fanout prefix".
Do not use fanout on the writer itself, this will cause the neighbourhoods to go to layers instead.
gio
Forum|alt.badge.img+15
  • Jun 17, 2016 2:38 PM UTC
