Group by in a Custom transformer with Spatial Filter
  • Feb 13, 2018 3:08 PM UTC
  • 87 views
I have created a linked custom transformer with a loop and a spatial filter. In this transformer I check if a line feature intersects with an area, but only if they belongs to the same group. So I thought I had to use the Group By parameter in the spatial filter.
The problem is that my custom transformer does not work with the Group By parameter. I mean, if I do not define a Group By some lines pass the test (but not belongs to the same group) but if a define the Group no line passes.
This is my first custom transformer, so, any suggestions would be appreciate
Thanks in advance
Víctor
gio
Forum|alt.badge.img+15
  • Feb 14, 2018 2:28 PM UTC
Should work.
Are you sure the groups are well defined and the relevant attribute propagated?
Also it is a blocking, so all the inputs are collected prior to filtering.
Maybe you want to iterate trough the groups (custom) and then feed the custom to filter them. (custom within a custom)
For instance If a line crosses trough more then 1 group ad intersects polygons in more than one of these groups, it will only get used once. Meaning that cloning the line or chopping it up is required..
Should work.
I found my mistake. I had a FeatureHolder just before the SpatialFilter and this was the problem. A newbie error...
Thanks a lot for the answer!
