Go from "local" named connections to shared named connections
Forum|alt.badge.img+50
I have a couple of named connections set up in FME Workbench and they're currently stored in the default location (wherever that may be). How would I go about migrating those to a shared set of named connections on a network drive?
At first I was able to right-click on a named connection, choose export, save it as a .xml file, then specify a named connection file in the Default Paths tool (which creates an empty one) and import the .xml file there, but after a restart of FME Workbench that right-click option has disappeared. Happens on both FME 2015.1.2 and 2016.
Best answer by david_r
I just tested going into FME Options / Database Connections and right-clicking on the entries works fine, I get the context menu with the export as XML option.
Using FME 2016.0.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • February 1, 2016
Using FME 2016.0.
  • February 1, 2016
Aaaand... it's back here too... Am I going crazy? (no, wait, don't answer that...)
