Get folders name with Python
  • Jan 5, 2016 12:35 PM UTC
  • 60 views
danilo_fme
Forum|alt.badge.img+58
Hello all,
I have a Folder with subfolders:
How can i get the names subfolder with python?
Thanks in Advance,
Best answer by takashi
An example.
>>> import os
>>> root = 'C:/Data'
>>> for file in os.listdir(root):
...     if os.path.isdir('%s/%s' % (root, file)):
...         print file
"os.walk" can also be used. See also the Python documentation.
BTW, why not use the PATH reader?
  • Jan 5, 2016 1:04 PM UTC
An example.
>>> import os
>>> root = 'C:/Data'
...         print file
danilo_fme
  • Jan 5, 2016 1:50 PM UTC
Hello @takashi thanks your help. It was very important. :)
The reason that i don`t use the Path Reader on this case, is because i use in my workspace the Shutdown Python.
Thanks agian,
Danilo
