Geographic orientation
  • Apr 28, 2026 8:39 AM UTC
  • 6 replies
  • 182 views
aymeric17
Forum|alt.badge.img+4
Hello,
In FME Form, I am trying to generate a line from 3 parameters:
  • lon/lat (WGS 84)
  • length
  • geographic orientation (from geographic north, in degrees)
I have tried several ways to build this line (2DDirectionExtender, VertexCreator + Offsetter (tested polar coordinates or spherical coordinates), VertexCreator + Rotator)
Always the same result, when I measure the angle from geographic north, there is a difference for instance, with my input:
  • lon/lat : -4.49027778, 48.02000000
  • length : 0.002
  • orientation : 100.478°
In both methods, FME gives me this result:
When I calculate the bearing from start point to generated end point, it gives me the same result 105.411° (same with online bearing calculators using coords)
Any idea on what could be wrong?
Thank you
hkingsbury
Forum|alt.badge.img+73
  • Apr 28, 2026 8:00 PM UTC
I suspect this is probably a coordinate system issue…. ​@redgeographics My mind first jumped to you for a solution
Forum|alt.badge.img+63
Most likely coordinate system, yes. But I didn't pay close enough attention in geodesy classes 😅 (and I'm on a little holiday at the moment).
I would also like to point out that since you specify the length in WGS84 degrees and the length of a degree differs based on your position on earth and the direction you're measuring in, your method may introduce errors (can't get my head around those at the moment)
aymeric17
  • Jun 2, 2026 9:42 AM UTC
Thank you for your help.
I used the length in WGS84 degrees to simplify the use case for the test. The exact length isn’t important at this stage since I reproject to a local projection when I need accurate measurements 😊 The length is therefore correct — only the rotation is incorrect.
I’m still stuck on this issue. Any other idea?
crystalwang
Forum|alt.badge.img+31
Hi ​@aymeric17,
Thank you for posting your question on the FME Community!
Although I am a bit rusty with coordinate systems, would it make a difference if you reprojected to a projected coordinate system (eg. EPSG:32630) before building the line? Then after, reprojecting to a geographic coordinate system such as WGS84 if needed.
aymeric17
  • Jun 23, 2026 2:34 PM UTC
Thank you for your reply.
Well, I tried also with a local projection and I thought the difference between the measured angle and the true azimuth came from the grid convergence of the local projection. That’s why I tried to build it in a geographical coordinate system (WGS 84). But same results unfortunately.
crystalwang
Hi ​@aymeric17,
Thanks for the extra detail. Would it be possible to share a sample workspace with some sample data illustrating this issue? This way, we could take a closer look at what might be happening here.
Thank you for your patience while we troubleshoot this!
