FMEFlowJobSubmitter 'Error communicating with FME Server host"
  • Feb 14, 2025 2:08 PM UTC
  • 0 replies
  • 145 views
fabiank_gitter
Forum|alt.badge.img+7
Hello!
I have a problem regarding using a FMEFlowJobSubmitter within a workspace when running on fmeflow using only one engine. When testing the same setup on an old fmeserver i dont have this problem since a “child” engine is created and the procces does not halt. This also works ony my localhost fme flow.
However when running on a new fmeflow setup i get the following error:
346 2025-2-12 14:53:56 | FMEFlowJobSubmitter_5 (ServerFactory): Reason - 'Error communicating with FME Server host
FME-flow uses a “"FME Engine of a distributed FME Server deployment". Could this cause the issue or is there any other known problems that i can look into?
/Fabian
