FME workbench on Windows Scheduler
  • November 28, 2013
  • 77 views
I have a workbench that I want to run on windows task Scheduler. What windows scheduler did was just opens up the workbench but it actually didn'tt run. I have workbench that downloads the data and save in my local geodatabase? I wanted to schedule a task so that it downloads the data everymonth?
fmelizard
Forum|alt.badge.img+19
  • November 28, 2013
Have you batched the workbench? (File> Batch Deploy) after schedueling the .bat file that workbench should run as saved.
Itay
  • November 28, 2013
another option is to copy/paste the command line from the FME workbench log window. When you run it manually, the top lines in the log window will contain the necessary parameters, e.g.
You can then define a scheduled task like this:
The add arguments need to contain the complete path to the workspace (.fmw) file as well as all the other parameters on the same line. In the above case, it should read:
d:\\temp\\test_workspace.fmw --SourceDataset_SHAPE D:\\Temp\\NewFeatureType.shp --DestDataset_FILEGDB D:\\Temp\\test.gdb
David
  • November 28, 2013
That was very helpful and it worked well. Thank you Italy and David.
