FME Workbench 2020 throws error on exit
  • May 11, 2020
  • 105 views
dms2
Forum|alt.badge.img+11
I installed FME 2020.0.2 (build 20232 -win64) on a Windows Server 2012 R2 Standard 64-bit (6.3, Build 9600) machine.
It works fine but throws an error message on exit and I'm concerned it may hide some important unwanted functioning I haven't found out so far. Before installing FME Desktop on our production server we want to make sure everything works as expected, so I can't overlook this apparently minor thing. Any idea of what is it about?
A repair install did not solve the problem.
See error details below:
Application Name: fmeworkbench.exe
Application Version: 2020.7.39.20232
Application Timestamp: 5eab95e4
Fault Module Name: Qt5Core_fme.dll
Fault Module Version: 5.12.3.0
Fault Module Timestamp: 5cffcf60
Exception Offset: 0000000000028658
Exception Code: c0000409
Exception Data: 0000000000000007
OS Version: 6.3.9600.2.0.0.272.7
Locale ID: 3082
Additional Information 1: 9fd4
Additional Information 2: 9fd4a669fc1d4902f2a6c086b5be2368
Additional Information 3: ad84
Additional Information 4: ad842c100b5ae85309684d1ce12ce40a
Best answer by erik_jan
This is a typical case for FME support: https://www.safe.com/support/report-a-problem/
I am sure they would like to know if an issue like this occurs.
erik_jan
Forum|alt.badge.img+19
  • May 11, 2020
