FME Server provides Authentication and Access Control using the Java Authentication and Authorization Service (JAAS) framework. Is the way of Authentication/Authorization subject to change ?
  • Oct 20, 2020 10:20 AM UTC
  • 14 views
vini.devgan
Hi @vini.devgan​ ,
I have spoken with you via email about this, but in case other users have the same question - Yes we do use this framework however it is subject to change. Please let me know if you have any concerns about this that I can help address.
