FME server fails to display the fme app result url directly after running the app successfully,
  • Apr 4, 2020 8:14 PM UTC
  • 5 replies
  • 114 views
lubna_najeh
Hi All,
Why the FME server fails to display the fme app result url directly after running the app successfully, I think It’s difficult to the end user to go back to resources with user name and password to download the result of the used app!
What do you think?
Best,
Lubna
Best answer by danilo_fme
Hi @lubna_najeh
I think your workspace is not rEgistered service Data Download.
When you executed the Workspace , thE workspace return a Link for download.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Apr 4, 2020 11:48 PM UTC
Hi @lubna_najeh
Thanks in Advance,
Danilo
lubna_najeh
Hi @danilo_fme, how I can do that, It will be nice if you show me how to do registering service data download
Thanks in advance
Lubna
Thanks in advance
Lubna
Hi @lubna_najeh
You must register the workspace to the service you'd like it to run under during workspace publishing. You must check the box and then select Edit under the Service Properties to choose what writer outputs are included in the zip file provided to the end user on workspace completion.
Then when you create the Server App and select the workspace, if it is registered to multiple services, make sure you selected Data Download.
lubna_najeh
Hi @lubna_najeh
Thanks in Advance,
Danilo
Thank you for your help, now its working with me and the output data can be downloaded directly after enable DATA DOWNLOAD SERVICE
Best,
Lubna
lubna_najeh
Hi @lubna_najeh
Thank you @hollyatsafe for the additional information :)
Best,
Lubna
